Anyone between Ft. Hood and Austin have a trailer I can borrow around Aug 15th?
Scuba_Steve
152
May 28, 2009
Colorado Spring, Colorado
I am coming home on R&R from Iraq on around the 15th give or take a few days, and need to get my car on post so I can do some work on it at Sprockets so it will pass an emissions inspection. The problem is it doesn't have valid plates, inspection, or post stickers. I need to bring it in on a trailer. Does anyone have a trailer I can borrow for a day? It's an AWD so a full trailer is required. I would be towing it with an F150.
Thanks!
You can rent one real cheap in Killeen for the day. I'll be home about that time to but I'll have my hands full with a new baby. If I was free I would help you out. Also U-Haul has a trailer that works great for this car, I got it when I took my car to Dallas to install my new engine. Whish I could be more help, sorry.
Thanks Don,
Congrats on the new baby! The work I'm doing is pretty basic, just a dp and cat replacement. Getting it on post is the only real challenge. Where can I rent that trailer you spoke of? I know Uhaul has them, but I'm to cheap to spend $50+ :p
Now the work I plan on doing when I get back home for good, that is another story.... Ball joints, tie rods, struts, half shaft, mounts, clutch.... I might as well just remove the entire front end!
