DSM's 4 life
- 649
- 14
- Nov 13, 2011
Buffalo,
New York
I tried upping my injector deadtime but its almost at 300... how would i lower my combinedft more?
the 02 sensor isnt cycleing when I simulate it.
You need to select the front o2 as your wideband:
I'm betting he wired it to the pin 76...
I hooked up the blue wire on my aem eugo to my baro input off my ecm maf cable and the white wire to my front 02 sensor
I removed the baro input.
My sensor is in the front o2 housing does that change the prosedure you said about unpluging the rear?
I have the white wire on the aem hooked up to my front 02 pin 76
In that case, no need to unplug rear o2. Just set up narrowband simulation, and you should be good to go. No need to hook up anymore inputs, ecmlink will log and do narrowband sim at the same time.
... I need help and no one is giveing it maybe some motivation will help solve my issues.
I'll go out on a limb here and speak for most of us that are willing to put our time and effort into helping with your tuning issues: This is a two-way street; if you don't put the effort into holding up your end of the deal and take care of the items mentioned below, don't be surprised if your help suddenly dries up and/or your thread is locked. You've been warned!
With that said, here is a list of things that you are responsible for checking and/or fixing, before asking for help with tuning. Please start your post with either verification or numbers (in the case of a compression test for example) for each item, so we can save time and get down to business.
My next question is are you positive you tapped the white wire from the AEM to pin 76? There are two white wires right next to each other.
Have you also searched on here to find how to set up the voltages and readings for the AEM unit in link via linear wideband, and then performed those steps?
Your AirflowPerRev is ridiculously high, so obviously your idle isn't dialed in properly. You might not be able to get it down to .26 with cams, but it shouldn't be too much higher.
Make sure to go through this list in full. In regards to the high value, focus on step 12, specifically video 8 on that page.
http://www.dsmtuners.com/forums/ecm...97-please-read-before-you-ask-log-advice.html
