TALON the TSi
- Aug 22, 2012
Derry,
New Hampshire
All Stock 1995 Eagle Talon TSi. odometer reads 74k Miles , i had my brother and some of his friends look at it before i bought it they said it looked good, but there was a good amount of rot. so i bought it for $1500. Right after i bought it i replaced the rear left brake rotor and pads. bought myself a nice pair of Tires for the stock front rims because they had like no tread left.i think the measurements for them are 205/215/R16. last thing i did was bought a new spectre air filter and 2 new high beam bulbs for the headlights. went to go get the car inspected and it failed for a bunch of things ill list them
-Rot in the Right and Left strut tower ***
-Rot in the floor supports
-Rot in the rocker panel
-Rot in the radiator support***
After it failed i still had some money to spend so i bought a brand new radiator support from a buddy off of one of his Eclipses. and i bought like 12 square feet of steel plating to do some welding.
10/05/12
Finished welding the strut towers***, then moved onto removing the rotted out radiator support. i got 90% of it off but the part that is bolted onto the frame in the middle was still on. We started undoing the bolts, got one out no problem but on the second bolt the whole metal piece spun around fast and smashed into my radiator, which started leaking pretty fast.*** pulled the hoses off of and pulled out the leaking radiator.
10/7/12
Ordered a new radiator From Ebay (hopefully not a bad decision) for $113. Picture shows a full metal, OEM size radiator for a cheap price, and im low on money so i couldnt buy a better one.
Pictures of the new radiator will be up once it comes in.
10/05/12
10/7/12
