So i finally got my motor sent out to get cleaned and pressure checked and heres my list of bottom end parts that im ordering.
6 bolt DSM H beam ARP 625 Manley 14021R6-4 **700 HP rod** 1 538.87 538.87
6 bolt DSM I beam ARP 2000 Manley 14413-4 **700 plus, will
6 bolt DSM 85.5 mm bore, 2.0l - 9:1 Manley
Mitsubishi 4, 4G63/4G63T, up to 1992 Race Series ACL
4B1146H-STD,1st Gen DSM Standard Size High Performance Rod
Bearing Set
Mitsubishi 4, 4G63/4G63T, up to 92 Race Series ACL
5M1144H-STD,6 Bolt 1st Gen DSM Standard Size High
Performance Main Bearing Set
Eagle 2034655900A6- 4G63 Crankshaft For 6-Bolt, 88mm
6 bolt DSM oil pump TOP OPMI6
1G DSM complete gasket kit TOP CGSMI6
MIT 4G63/T 85.5MM .051"MLS Cometic C4233-051
Mitsubishi 4G63 M12 head stud kit ARP
Mitsubishi 2.0 4-cylinder 12pt main stud kit ARP
Gates T167RB1-Gates 03-06 Evo / 95-98 Eclipse Turbo / 90-94
Eclipse / 89-92 Galant DOHC / 90-94 Laser / 90-94 Talon / 95-98
Talon Turbo Racing Performance Timing Belt ONLY
Thats just the bottom end, Im looking to get atleast 700whp still deciding on what kind of turbo i want to add to this but thats down the road,
The transmission just got shipped out on Tuesday to Shep trans to get their stage 3 upgrade with a welded diff. that will hopefully be done and on its way back in 2 weeks. The head now has a 5 angle valve job with ported and polished intake and exhaust sides.
