dugjr24
- 57
- Nov 2, 2002
Cincinnati,
Ohio
I just replaced my slave and master cylinder do to my clutch sticking to the floor. Since then whenever I shift directly into 2nd I get a little bit of grinding even when the clutch is fully depressed. All other gears are fine. Although if if I briefly put it into nuetral before shifting to 2nd it shifts fine. Does the master cylinder rod possibly need adjusted or is it a tranny synchro problem?
