GBabyTSI
- 102
- Dec 1, 2002
Lake Charles,
Louisiana
I just changed my clutch slave cylinder 2weeks ago and bleed the system and everything worked fine. but 2 days ago i was driving my car and the i pressed the clutch in and triedto put it in gear and it would not go in to gear.I tried bleeding it but it only helped a for a couple pumps on the pedel but the pedel doesn't stick to the floor it comes up ever time and the only place it looks like the fluid is leaking is from the seal around the piston of the slave cylinder but i can't really tell and if it is it is not bad cause my fluid level doesn't loook like it is going anywhere and i don't know what the problem could be. i am going to get a slave cylinder rebuild kit and a steel braided clutch line to see if that helps but i f any one knows of something that might help please let me know thanks
Gary
Gary
