1G AWD Tranny will not engage any gear
dsmike
91
Jul 21, 2002
A couple days ago my tranny had problems getting into some gears. I'd pump the clutch a few times, then it would engage. The next day I couldn't get it to go into any gear at all. I have been able to get it into second gear only once since then. I started the car in gear, got lucky, and managing to get the car home. Any help or diagnosis would be appreciated, thanks.
did you check the linkage? check on the trans and under the console. Check the clips that hold the lines in place I had on come off and couldnt get it into any gear before.
Try bleeding your clutch lines before you go off and buy new hydraulics. Never know, might save some money.
