What is wrong with my clutch pedal??
LifIsPeachy02
362
Mar 3, 2003
Middletown, Ohio
Ok, i dunno what is wrong with my clutch pedal. If i just barely push the clutch with my finger it will go down a little and stick. If i depress the clutch all the way even with the car off it will stick a little more than half way up. Do i need to adjust the free play or what? i don't wanna have to put a clutch in it!! i don't have money!!
the clutch is fairly new...like a few thousand miles, not to old. changed the fluid when we did the clutch didn't change the master or slave cylinders. but the fluid level is fine.
i think my return spring might be weak. will that cause it? where can i get one is it a dealer item??
It only does this if i adjust the clutch to where it catches closer to the floor. if i adjust it up i doesn't do it as bad its really pissing me off
