Act 2600
manuel2063
May 9, 2003
99 GST
I had the dealer install a act 2600 after my tranny got fixed. I was told i needed a new clutch master & slave cylinder because they where leaking, so I replaced them, but it is almost impossible to put it in gear since the clutch was installed.
Make sure they bled your clutch hydrolic fluid and that there is no air bubbles in it.
Then have them adjust your clutch pedal. When i had my new clutch put in they had my clutch pedal adjusted way too high.... so high that when i had the clutch all the way to the floor it wouldnt go into gear.
I could only get it into gear with the clutch in half way. Take it back and have them adjust it. You can do it from inside the car under the dash.
    • 92AWDHX40
    • eclipsemf
