whitegst
- 53
- Sep 26, 2002
Austin,
Texas
Hey guys, i don't know what's wrong with my clutch but i was driving normal on 4th gear and tried to shift to 5th but it wouldn't go in so then i tried to downshift to 3rd but it wouldn't go in so i parked and checked under the tranny to see if there was any fluid/oil dripping but nothing. So i turned the engine off and wait a while and turned it back on, then gears went in fine for 1, 2nd then the clutch wouldn't disengage so i had to turn the engine off right away to stop and park. same thing happen again, can't get any gears in. I was like what the hell, it only has 70k miles and it was working fine til this morning. So i called the dealer to see if my extended warrenty would cover the expenses to repair/replace whatever is causing this damn problem, but they say it wouldn't cover for the clutch, and they want $1k for just the labor to replace the clutch(damn satan) So i called other shop and they're asking about $650 for parts and labor. Does this price sounds resonable or is this overpriced? I'm pretty sure it's not the hydralics, which is even worse. Does this sound like i need a new clutch or could it be other problems that's causing this? Can someone help me out on this?
Any advise will help, thanks.
