badboyr66
- 918
- Dec 8, 2002
eastern,
Washington
Ok here we go, I know that on 90- 91 awd DSMs if you had ABS you did not have rear LSD. But if it was a 92 or newer you can have both. I have a 91 TSI with ABS and I want a LSD rear end...But I was told the LSD rear will not match the gear ratio, plus my ABS will not work right. Anyone know for sure?[email protected]
. I think its already been said, but an auto LSD will not work on a 5spd. or vice versa. I belive the ABS will work though after a 3 to 4 bolt conversion....i dont see why not. Either way if you plan on going to LSD, trash the ABS. Its complete frekin garbage on a 1G
it will get in the way of everything you ever want to do to your car. Ever tried removing an engine with the tranny still attached? Much harder when the tranny has to come out the bottom. Even IC piping is 20 times harder with ABS...TRASH IT!!
