mitsugst95
- May 15, 2002
I had tranny rebuilt and a Clutchmasters HDSB from extrememotorsports.com installed early this year. about 1 month ago, I noticed a higher pitch whine when cruising and found out by just depressing the clutch the slightest bit (not disengaging it) it would go away. about a week ago, on the interested in 5th i punched it and the clutch slipped, then a few days later 4th, now 3rd. the release point is very high now also and it slips between gears a bit but in first and second it holds fine and higher in the rpms in 3rd it will be fine. Is the clutch toast for sure, is it possibly a throwout bearing problem, and is it possible just to replace the disc, or pressure plate.
thanx in advance
thanx in advance
