quick_silver90
- Jan 24, 2003
Hi,
I figured out it would be cheaper and easier to swap a JDM(trans and transfer case) alsong my current trans with 230000 on it.
Does the JDM tran combo include the transfear case rear segment I believe I am leaking trans oil from it. WHich is another reason why I will replace the trans.
Ok first my car is a 91AWD And I bleive it has the smaller spline number. Know if I get a JDM tranney can I ask for the 92 pus version with a greater spline number? Or should I ask for the pre 91 version?
Since I will have everything apart for the trans swap. What wearable Seals/ Parts should I replace?
Thank you,
Shane
Thank you,
Shane
