Clutch question from a noob
Circus805
45
Apr 20, 2003
Lompoc, California
Ok, so i have a 96 Eclipse GS. when i first bought the car, the clutch went out on it. I had a stock one reinstalled and then i went on about my bussiness. Just the other week, it goes out again, after 11k miles. This time when i replace the clutch i want to upgrade to something better, with hopes that it might last me a couple more thousand miles. I was looking at the ACT w/ 2600 lbs plate but im not sure if thats what i want. With all the talks of engine damage and clutchwall or something, im really unsure. Just asking for a little advice on my situation.
Thanks,
-James-
seeing that ur non-turbo(if u had turboed ur gs it would be a different story, i dont know if ur gs is still non turbo) a 2600 would be overkill, its really unnesicary, a 2600 is made to handle heavy load of launching high powered turbo cars, but a 2100 will propbally work well for u, or a clutchmasters stage 1 would be perfect for ur car, my friend out aCM stage1 in his non-turbo 3000gt and he is very happy with it
and if ur cl7utches areburning oyt that fast there has to be a problem somewhere, a band new stock clutch should last for a long time if u installed it properly and had the flywheel machined, if it really wore out in 11k there4s either a mechanical problem with ur car or ur not driving very well and burning out the clutch
Thanks alot.. going to purchase the ACT 2100 right now.. thanks for the info...
James
I tried to buy the ACT clutch w/ 2100 lbs plate.. and i was told that it is only for turboed cars.. is there an alternate clutch that is just as good as this one? or can i still get the clutch and have it installed just fine?
-James-
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
