Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 07-25-2002, 07:08 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 95talontsi is an unknown
Am I screwed??
I am in the processe of taking out my trany, followed all the instructions, up to taking out the driveshaft, instructions say to support engine. I don't have a engine lift, do I have to support the engine? or can I do it another way then with a lift, or am I screwed??
Offline
Related Auctions
Sponsored Links
Old 07-29-2002, 01:07 AM   #2 (permalink)
Proven Member
Reputation: 91awdtsi is an unknown
well i have a 91. drop the cross member under the trans and there should be one under the motor and the trans should juat about fall out. but you can always use a jack stand or a jack.
Offline
[posts] Reply With Quote
Old 07-29-2002, 08:59 PM   #3 (permalink)
Proven Member
Car: 1998 Acura Integra GSR
Region: Midwest
Classifieds Rating: (1)
Reputation: imperial is an unknown
Being that you have a 2nd gen and 3 of the mounts are on the tranny, you'll want to support the motor with something. Even if it is bricks w/ a board on top to distribute the load across the oil pan. Just support it with -something-.
____________________________
Nick Thompson
10.8 @ 136
Offline
Old 07-30-2002, 06:57 PM   #4 (permalink)
Proven Member
thanks thinking about using a little jack and board on the larger part of the oil pan. or should I so with the smaller flatter part (where the drain plug is)
Offline
Old 07-30-2002, 08:13 PM   #5 (permalink)
Proven Member
Region: Midwest
Put the jack where you can support the largest amount of the motor, w/ the least amount of stress on the oil pan. Spready the load across the largest portion of the pan that you can.
Nick Thompson
10.8 @ 136
Offline
Old 07-30-2002, 09:07 PM   #6 (permalink)
Proven Member
Reputation: mclaren55 is an unknown
I have taken out my tranny 3 times, never once supported the motor. She is still in one piece. Just do it quickly, me and a buddy are usually done within 2 hours. Unless you are rebuilding it, you can usually let the motor "hang".
Offline
Old 07-30-2002, 10:02 PM   #7 (permalink)
Proven Member
Reputation: KenTSIII is an unknown
I don't personally have a 2g... but I've helped change a clutch in a 2g once (& waaay too many times on a 1g)... & we had a 2x4 board cut to go side to side across the engine bay... & then supported the motor w/ a strap (like used to secure stuff in the back of a p/u truck).. worked quite well.. the rachet straps would ###### work well also.
Indy Race Cores
Offline
Old 08-10-2002, 03:58 AM   #8 (permalink)
Proven Member
Reputation: blackvr4 is an unknown
Its easy if your worried 2 pieces of 4by2 wood blocks steel pole from your local park swing and a the chain + 10mm bolt and nut.:laugh:
Offline
Old 08-12-2002, 08:04 AM   #9 (permalink)
Proven Member
yeah I got it, used the scissor jack, a peice of wood and a bunch of towels, will see if the oil pan is in good shape, I don't think I'm worried about it just lifted a 350chevy with a auto tranny by the oil pan.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.13736391 seconds (74.70% PHP - 25.30% MySQL) with 9 queries
