crankwalk?
It is really hard to say withoout seeing, but the amount that the crank "walks" is not a matter of inches, it is a matter of millimeters. It is also fairly rare for a 1G car with a 6 bolt engine to crankwalk. I would make sure that your timing covers, etc were fastened properly.
The AC/idler belt jumped the pully and sandwidged itself between the pully and the plastic cover. I cut it away and then had the enging started. The pully moved out a little and then back in to original spot. Now it is slowly cutting away the plastic cover like it is pulling itself in or something.
