350 hp auto trans...
Coldandafraid
1,147
3
Mar 1, 2003
Edmonton,
Most parts that I need to make my engine produce around 350 hp are in the mail as I write this, however, Im wondering if the stock auto tranny and things are going to be able to handle the engine. What do I need to do to my tranny to make it last?
I am running between 330 and 350Hp. My tranny slips quite bad between 2nd and 3rd. What I am in the process of doing is installing a Shift Kit, an End Clutch Kit and upgrading my Torque Converter. I have a post waiting for comments regarding 3 different TC.
Dan
With those mods you will be fine. But if your trans has slipped already that is bad. The shift kit will delay an untimely death. Once you slip clutchs they are usually toast. Since the trans still moves I would overhaul it. It will be cheaper now than when it self destucts.
It only slips at WOT. The tranny shifts perfectly otherwise.
Dan
Is it slipping when shifting or slipping when in gear?
Initially go with the shift kit and end clutch kit, but if you want less drive train loss - more power to the wheels and better torque, go with the Torque converter. If you only want to strengthen your tranny, go with the first two.
Shift Kit approx $75
End Clutch Kit approx $75
Torque Converter approx $1100
The cost of the TC is quite significant.
Dan
    • 92AWDHX40
    • eclipsemf
