Antilles
- 305
- Aug 25, 2002
Savage,
Minnesota
The car is a 92 AWD in the 12's and shooting for high 11's
I just ruined my second gear syncro so it looks like its time to rebuild. I'm pricing options for the tranny I need help deciding on a few things.
-Double syncro 2nd. I really want this one because thats the weak part that broke on my tranny. Are these things really that great and do they hold up to drag racing well?
-Evo shift forks. Are the stock ones really that weak? Do the evo forks need machining to fit? TRE's forks are double the price of Conicelli's Evo forks, is there a reason for that? Also, is this something that can be done easily later without removing the tranny if a fork breaks?
-Steel shift rails. I have heard that these are as important as the evo forks. Are the stock iron rails likely to fail during hard shifting? Again, can these be added at a later date?
All new syncros are a must, and i think i will need at least 2 new gears, 3rd and 4th. Does the syncro kit from TRE cover everything? I dont understand what the deal is with their $180 1st through 5th syncro set. What about hubs and sleeves? Are those included. There is an extra charge for the syncro set if you have a double syncro second gear....if im paying $300 for the double 2nd, do i have to pay extra for the double second syncro set?
This is a lot of questions, and I hope someone here can help me out a bit. I will probably have to just call TRE anyway but a heads up on some of these questions at least would be great.
Chris
Chris
