ASZRAEL1266
- 895
- Oct 15, 2002
Just when i got my car running good somthing has to go wrong. On saturday i put in my new 16G turbo and i drove around all night. Well that same night I took a look at my miles and noticed that ny clutch is just about broken in so i thought i would do one launch with it to see what it can do. Well to make a long story short when the car took off i heard a very loud thunk sound. I freaked out and took the car out of gear and just sat there for a second i put it back in gear and gave it some gas thinking that my tanny is probly toast. Well the car moved and i thought man this must be my lucky night. I drove alittle while and came to a stop sign and when i left the sign i gave the car some gas after i was rolling and the front tires broke tracktion. As soon as that happened i felt sick. I tried it one more time and it did the same thing. Now i am thinking it is either my tranfer case or my center diff. The car doesn't make no sounds or anything when i drove it home. I am hoping it is the transfer case becouse it is still under warrenty from when the dealer replaced it about 6 months ago. Is there a way to check it with out pulling the car apart? IF its the center diff is it a part of the tranny? If i bought a jdm tranny would it come with a new center diff? Oh and is it safe at all to drive my car like this for a short time like 2 weeks till i have the money to fix it?
, but it depends where it broke. You said that you needed a new carrier bearing, which means going into the diff to rebuild it, and have to get the lash set up and everything. Why bother spending the money on a 3 bolt rear? You will pay more money for SATAN to fix that rear then it will cost you to find a complete 4 bolt used.
.. didnt even bother to look at the dates until someone said something.
