transmission drawing anyone?
Jayson654
Jun 16, 2002
I have taken out my tranmisson to replace my stock flywheel and clutch with performance ones on my 95 gst. While i'm at it, i wanted to open up the transmission to inspect whether or not my gears and/or synchros had to be replaced. I was wondering if anyone has a diagram of the tranmission parts so my dissassembling and assembling will be much easier. The transmission code would also be helpful.
just go to pepboy's and get the haynes repair manual it will help or when you take it apart use masking tape to lable the partswhere thay want and order that type of thing
If you want a drawing just go to your local mitsu dealer, but if your not having any problems with your trans leave it for now. Once you get in there if the synchros are worn youll probably have to replace the 1-2 hub and sleeve assembly, if theres alot of miles on it then you might need bearings, the rest of your synchros and once you start replacing parts you need to shim out the new selective shims. I've done alot of these and theres gonna be even more to do in there, so unless the trans is no good or you know how to do it LEAVE IT. If you have any ? email me [email protected]
