Rebuilding Tranny, What Parts do I need and what to look out for????????????
umiami80
302
Apr 16, 2002
Rebuilding Tranny, What Parts do I need and what to look out for???????????? (post #1)
Well my 4th gear stoped working and I still have a stock clutch so I went overboard and bout everything I can think of, here is what I got.
1.GVR-4 1st gear set & Input shaft
2.Spring, synchro key, BIG
3.hub & slider, input shaft, 3rd/4th, high capacity
4.snap ring, intermediate shaft, 1.50mm
5.bearing, inputshaft, 1st gear
6.seal, oil, case, left
7.seal, oil, right diff cover
8.seal, oil, outputshaft.
9.tre EGT probe
10.Shift Fork, 1st/2nd-3rd/4th AWD
11.snap ring, inp/int, 1.40mm
12.Brand new Fidanza Aluminum FLywheel
13.Clutch masters SPRUNG 6 Puck disk with 2500PP
14. Brand new Synchros from Satan himself 1-4 gears, #### 5th
What else should I get? What sould I be looking ofr? I believed that I destroyed my 3/4 Hub and sleeve and bought new forks just for good measure.
I will write a review on ther GVR4 gear, this will help me with MANY kills, Thanks guys any and all info would be great.
steel forks? ive welded or replaced too many of thoes 'white steel' aluminum numbers to rely on them. how about that 4 spider center dif?... 2nd gear double syncros?...
other than that, you seem to have everything correct.
the G-vr4 1st gear is crazy (ive got a GVR-4 tranny with a rectified USDM final drive). i get up to about 40 MPH before i shift *grin*. launching is pretty bad, especialy since ive got a 9 LB flywheel, 2600 PP, and a street disk... can you say 6500+ RPM launch? for some reason my 1st gear FEELS slow compared to second (i kick in 2nd gear and the car just pulls harder from there) but i equate that to a turbo problem. Have fun blasting around with a mile long 1st gear :)
    • dhssoccer24
    • LSM
    • LSM
