Cost of syncros???????
Pauly
Dec 9, 2002
My 2nd gear syncros are done what would it cost me to have them replaced in second? Labor everything.....
2nd gear doubles from TRE cost something around 65 bucks. dont know what their install rates are tho, if your not close to them you can ship it to em, i highly recomend them (and having a few of their other parts put in as well...)!!! but you can get their syncros put on at a local shop.
www.teamrip.com
www.bmtranny.com
www.shepracing.com
The syncro mentioned costs $65. What wasn't told to you is that you need a new gear and hub/slider assembly which will run you a total of ~$300. With the trans open, it behooves you to replace all syncros, bearings, seals, worn parts etc. Expect the rebuild to start at a cost of ~$600 with a possibility of reaching $1500 depending on what is worn, what upgrades you add, etc.
aaaaa this is crazy what if i just by a new one? im not gonna need linkage and everything? damn i gotta get this car running good by may 18th if it kills me.
