Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 06-01-2008, 03:03 PM   #1 (permalink)
Proven Member
Jeff822's Avatar
Car: 1990 Galant SOHC 4g
Region: Tri State
Classifieds Rating: (1)
Reputation: Jeff822 is more helpful than not
Wheels lock up
Well I just put a new transfer case on today after pulling my other one off and finding it to be destroyed, took the car for a spin and it drove fine. I brought it home and went to back it in the garage to check the brakes out and while in reverse after like 2 feet the wheels locked. I took the transfer case back off, took it apart to check it out then put it back on and went to leave again and started backing up and the wheels locked up again. I put the car in neutral on the incline and it was stopped dead, tried pushing it and it wouldn't move. Then put it in first and pulled it back in the driveway. The guy I bought the car off of said the car had a newer rear in it if that helps any. The number on it is B1G I beleive.
____________________________
90 GSX- Sold
91 TSi FWD- Sold
98 GSX A/T- Sold
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 06-01-2008, 04:29 PM   #2 (permalink)
Proven Member
cruisintalonawd's Avatar
Region: Rocky Mountain
Classifieds Rating: (2)
Reputation: cruisintalonawd is an unknown
new rear what???bumper? take the cover off the rear end to check it
Offline
Old 06-01-2008, 04:40 PM   #3 (permalink)
Proven Member
Region: New England
Reputation: talon187 is an unknown
check the splines on the transfer case and the input shaft sounds like they are not the same
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Drivers side door lock will lock but not unlock. I read all door lock posts. 95EclipseGST Problem Diagnosis 6 03-10-2007 07:50 PM
Rear wheels lock up under tight cornering droopynuts Drivetrain Tech 3 01-31-2006 09:02 PM
drivetrain problems :: rear wheels lock up Tomeek Problem Diagnosis 1 03-01-2005 07:56 PM
need help rear wheels lock while driving damnthecops Problem Diagnosis 6 05-25-2004 10:14 PM
my rear wheels lock up when i turn and i hear grinding noises when i turn xxtwistedpnoyxx Problem Diagnosis 1 10-27-2002 12:29 PM
Page generated in 0.10180306 seconds (66.00% PHP - 34.00% MySQL) with 10 queries
