Slave cylinder torque spec? (help fast, plz)
Spidey
1,420
11
Sep 22, 2002
Charlotte, North Carolina
I'm going to attempt replacing my slave cylinder(one on/near the front of the tranny) with the help of a friend and I'm following these directions:
http://www.plymouthlaser.com/slave2.htm
In those, it says "Line the rod onto the clutch release arm. Torque the slave to spec," can anyone give me the torque spec or tell me what to do? Any info will be appreciated.
Thanks in advance,
Spidey
The slave cylinder bleeder plug: 1g - 7 to 9 ft/lbs
2g - 8 ft/lbs
Slave cylinder mounting bolts: 1g - 14 ft/lbs
2g - 11 to 16 ft/lbs
Slave cylinder union bolt (U-bolt): 1g - 18 ft/lbs
2g - 17 ft/lbs
Thanks man. Now I have to go find a new hydralic hard line that goes from the resevoir to the slave cylinder because that is leaking too, and might've been what was leaking in the first place :( Don't suppose anyone has a part # for that?
