Peepers
- 120
- 4
- Nov 2, 2002
Toronto,
ON, Canada
Hey guys, got an issue I'd like to solve.
I recently put in a new CF DF clutch along with an ACT XACT Streetlight flywheel. The flywheel was properly stepped and double checked by Magnus to ensure it was correct.
I also installed all new supporting parts (OEM throw out bearing, new OEM slave cylinder, new OEM flywheel hardware, new OEM fork, clip and pivot ball). The clutch master cylinder is only a year old. Once everything was put back together I filled the tranny up with new BG SyncroShift and bleed the system properly (I think) clutch releases fine from what I can tell ¼ from the floor.
I also did the skateboard bearing mod and installed some urethane shifter plate bushings. While I had the tranny out I also changed out all motor mounts to be prothane & tranny mounts to have the prothane inserts.
Now, I'm have issues putting the car into gear just after starting and/or going from neutral (say at a traffic light) then pressing the clutch to go into first. Most of the time I have to put it into second (or another gear) and/or reverse and then it will find first. From there, it changes gears fine until I put it into neutral and this will start all over again. It's almost as if something not quite lining up and with a little persuasion it lines up fine.
I've past the break-in period for the clutch and now Im trying to sort this issue out
Any ideas?
Ohh yeah, before I did the clutch install, everything was fine with the tranny function
Thanks in advance!!
Peepers
Any ideas?
Thanks in advance!!
Peepers
