Syncromax question
sprayin92
Nov 5, 2004
honolulu, Hawaii
My question is will the royal purple syncromax work in my tranny? I asked slowboy cause they recomend it but they couldnt give me a straight answer.
Hays manual says API GL-5 SAE 75W-85W gear lube for the tranny
Royal purple says,
Synchromax is recommended for manual transmissions that specify an automatic transmission fluid or motor oil. It is also ideal for 4x4 transfer cases and / or 2-cycle and 4-cycle motorcycle gear boxes.
Synchromax is formulated with Royal Purple's synthetic, proprietary Synerlec additive technology, which offers improved shift quality over a wide temperature range and reduced gear noise.
Synchromax is fully compatible with all types of friction materials and offers excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers.
Can anyone clarify this for me? Will this work in my tranny and transfer case? 93 GSX 5-Speed.
Thanks for your help,
Brandon
Royal purple says,
Brandon
It will work in the tranny but I would reccomend something a little heavier in the tc. Redline shockproof gear oil seems to work well in the tc.
Ask Royal Purple. Small oil companies -such as Redline- are very cooperative with their customers, and are more than happy to talk with you on the phone. Their word should be the final one.
