20psi
- 74
- Apr 22, 2002
My idea is the same as everyone elses. How can I make the "height" shorter? Easy....cut it. Trust me it takes big b@lls to cut this work of art but it's worth it. Now for some simple physics, when you reduce the height on any shifter you will lengthen the throw! Here's a simple test. WITH THE CAR OFF shift from 1st to 2nd.(notice the throw) Now move your hand down 2" on the shifter and preform the same test you will notice the throw is longer.Here's the cool part, when you cut the B&M about 2" and set it to 50% you get a 30-40% shift throw reduction.Follow me? I have'nt tried it with the 35% setting but it should be close to stock throw. Mounting the shift knob gets tricky. I rethreded mine with a 3/8-20 tap & die.I also used an OBX shift knob with unversal threaded which taped to match my new threads. Some other shift knobs mount with screws(MOMO) at the bottom of the knob. This is an easier way but I have found they vibrate loose.
Try it.
NOTE: Take the shifter out when you do the rethread.
Try it.
