Steel Shift Fork Bushes
nzphat4
Oct 29, 2002
Guys,
I'm in New Zealand and I'm just in the process of rebuilding my tranny .
I have the Evo 3 spec steel shift forks in the trans and when I pulled it down i noticed that one of the Nylon wear pads / bushes on the shifter had gone
Q: - Do I need to replace the entire fork due to this part going walk about or will it shift just fine without it ?
Any help would be great
Cheers
Byron
You would need to have a compentent machine shop either replace the wear pads with bronze wear pads or entirely replace the fork.
I have heard this happens a lot. One question I have is that these are production forks put on a production car. Do they come off on the Evos as well?
When mine wore out it wouldn't let third gear slide in all the way, and it damaged the engagement splines on the gear and the slider so it constantly popped out of third gear. That sucked. TRE puts bronze pads on the ends of the steel forks. Try www.teamrip.com Lots of cool info there.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
