BaddAssGst
- 1,054
- 21
- Dec 27, 2004
Toledo,
Ohio
So I had a perfectly shifting FWD turbo that I was driving before, but I ended up buying an AWD and just had some questions.
1) On the 1-2 shift at like 6500-7000, it seems like it takes a second to actually shift it? My trans doesn't grind at all but it just seems like it doesn't get into gear as fast as it should. I run an 18g so spool isn't bad but I think if I ran a bigger turbo, it wouldn't really stay spooled because of the time it takes to shift.
2) On the 2-3 shift, sometimes I get the same thing but not to often.
no question here, just a heads up?
3) On the 4-3 downshift, if I don't rev it, it kind of like clunks going into gear. Not really a grind, because it goes into gear, it's just more of a clunkiness sound. It's hard to explain.
The 2-3 shift is okay which makes me believe it's not syncros but only on a standard downshift does it make the noise but if I tap the gas and give it a quick rev, it goes into gear fine. WTF
My questions for the day. Help me out. Other then that, AWD freaking ROCKS.
Trans/Drivetrain mods: 2600, fidanza flywheel, ss clutch line, and possibly some type of short shifter. I don't know if it was cut down or what, but it's definitely not stock.
no question here, just a heads up? 3) On the 4-3 downshift, if I don't rev it, it kind of like clunks going into gear. Not really a grind, because it goes into gear, it's just more of a clunkiness sound. It's hard to explain.
