1G AWD Tranny prob.
hybridkid
Dec 9, 2004
Some Where, Pennsylvania
Ok my problem is i got a awd 92 talon. When i shift in to 1st and push in the clutch it won't come out unless you turn off the car and stop. I haven't checked the slave cyl. im not sure how the clutch is but as far as i know it has the stock clutch in it. and has 96,000 miles on it. thanks jay :talon:
when car is running? shift from what gear to first, start in first when you turn on car? start from nutral? what happens if you try to start from second gear? at what speeds? throw some more info this way would help alot good luck
:dsm: sleepygsx :dsm:
check slave and master cylinder.does it work better when you pump the clutch.bleed the system.
Sounds like you're having disengageing problems. The easiest thing to do is replace the slave and master clutch cylinder, you can buy them both new at Nopi.com for about $60 bucks. :talon:
