im thinkin bout buyin a car and i need help, thx
still has the heat shield on exhaust mani ..looks clean and nice.
If your in for a FWD, compression test it..drive it..like it..buy it..test EVERYTHING..sure..you day "duh!"..but I ended up with a car that has no wiper fluid container or washer motor. not something usually checked.
when buying a car just assume your being lied to...
Sounds good, just double check..tester is only 30-40$
vfaq.com has the procedure if your not familiar with it, quick and easy.
