Problem with the clutch...
Auladan
304
2
Jul 3, 2002
Shelton, Washington
Well, I'm not sure if it's supposed to do this, or if somethins wrong, but when my car is runnin cold, a 90' TSI AWD, the clutch will grind if I shift as quickly as I do when its runnin warm.
Whats up?
Also, this just started, but when I'm in 4rth gear and I hit 4rpms, my car begins to lug... Just like if you start movin in first gear not knowing how to drive a stick, without killing it.
Any ideas?
Well if you mean that it grinds when it is cold. I would change the oil in your tranny if you have not done it yet. These trannys will grind when cold if you put 80w90 in them. Put 75w85 GL4 in it. If you have change the oil already you might need a good overhaul.
