AwdGte
- May 15, 2004
None,
Maryland
I have searched and can't find any info on this ...
I just purchased a 93 GSX 5 speed, that had what was said to be a leaking axle seal, turns out someone cracked one of the transfer case bolts, I assume they drove a bolt down that was too long, with an impact gun, and when it pressed against the part that bevels, it split it. Its a hair line, but leaks a lot when warmed up and the fluid is more viscous.
It leaks from that bolt hole pretty bad. Instead of putting the transfer case back in, etc etc, I pulled the trans out. I can TIG weld, but have no idea how to get that front case (bell housing) off of the rest of the trans ... any tips?
I'll replace all 3 seals, and I guess use some sort of bond, maybe RTV to seal the case back up?
Has anyone had this happen to them, or purchased a car like this?
