RossY
- 627
- 2
- Sep 27, 2002
Canton,
Ohio
Ok i started my car today after putting in a new clutch. I pushed the clutch in and tried to get the car in gear and it would grind as if the clutch was not being pushed in. So i took a look under the hood while my brother pushed the clutch and the piston that pushes the clutch fork was pushing the clutch fork what seems to be as far as it could. When pushing the clutch it does feel like there isn't much resistance and the pedal doesn't pop back out as fast as it should. I bled the system to where there's no air or at least no more is coming out, but the problem remains. The only thing i can think of would be if the throw out bearing isn't attached to the clutch fork correctly and therefore im not getting the resistance in the pedal because the clutch plate isn't making contact with the throw out bearing. Ive tried starting the car while in gear with the clutch in and it seems like im not pushing the clutch pedal at all. I have a 90engine w/ a 2g fwd tranny. Any ideas?
