2nd gear launch
why would you want to? if this is a real issue for you then maybe you need more practice or a dual stage mbc
my first gear is done so fast it's rediculous. I was just looking for someones experience at the track that has tried it
It would probably just burn your clutch up, if first gear is too fast for you there is an easy fix, dont press on the gas so hard :)
If you have a lot of torque then it may be realistic to launch in 2nd, the 1st gear ration is pretty high for fwds, and I think Sean Glazer ran a best time in his old fwd Mirage launching from 2nd.
aahh I don't know man you need to learn how to shift faster because I don't think you can use first of vr-4 on 97
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
