How fast with this setup?
eclpsegsx12
214
Feb 16, 2003
Tucson, Arizona
I have a 2g gsx with 3 inch full exhaust, intake, mbc,cbv,UICP,fuel pump,1g cams, and s-afc II....i ran a 14.3 without the cams and s-afcII(which is adjusted).....i am picking up a small 16g and the act 2600 lb clutch very soon.....im wondering what to expect in the 1/4 mile with this setup....the acf will be tuned better and i am hoping to have an FPR by then also.....thanks a ton :dsm:
hey jon, this is jeff from omaharacing......i am hopin for low 13s at least........any other relpies would be helpful.....also, what would a 90 talan tsi awd with the stock turbo, emanage, 3 inch exhaust, intake, mbc,bov,IC piping,act 2600 lb clutch.......im just wondering if my setup also could beat the 90's setup in the 1/4 saying that the drivers are farely equal....thanks
your 60' time is key, if you can pull around a 1.8 then i would say low 13's would be very achievable.
I would say low 13's. Possibly a 12.9 or something it really depends on turning or if you want to run race gas.
