98TsiAWD
DSM Wiseman
- 2,861
- 8
- May 19, 2002
94 3000GT VR-4,
North Dakota
Here are my mods on the car so far:
K&N FIPK
1g BOV
Brode Upper IC Pipe
MBC@15psi
Hacked Dump Tube
Sheetmetal Cold Air Box
Greddy Lower IC Pipe
Accel 8mm Blue Plug Wires
NGK BPR7ES Plugs
Dejon 2.5" Turbo Inlet Pipe
Hahn Upgraded Sidemount IC
3" RNR Racing o2/Cat Eliminator Turboback Exhaust
I have a Denso 190lph pump, 95 eprom, and IC sprayer I need to install. I first need to send off the eprom to get socketed for DSMlink tho.
The fastest T25 time on dsmtimes.org is 13.404
I want to beat this, and not just barely, I want to get ~13.2
I will not be doing any kind of weight reduction either, I dotn even want to remove the spare tire or back seat.
After I get the DSMlink and install the fuel pump, I plan to get either a CFDF 2500 or ACT 2100 clutch, Port my Exhaust Manny, EGT, and 660 Injectors. Do I need the injectors for the T2small? Or will the 190 pump and stock 450 injectors run enough fuel for say 17psi? I dont want to run anymore than that since it would be nothing but hotair.
Will I need suspension to get there? I am looking to get the Tein SS coilover system. But If that can wait that would be nice since that costs around $1k.
Now I am assuming Race Gas will be a MUST in order to run ~13.2 on the T25?
Thanks for all the input, I want to accomplish this goal..
K&N FIPK
1g BOV
Brode Upper IC Pipe
MBC@15psi
Hacked Dump Tube
NGK BPR7ES Plugs
Pass me what you're smokin if you think you're going to go from a 12.7 to a 11.9 with cams/stand alone.
He ran around 20PSI IIRC as well. With street tires.
