| Drag Strip Preparation, technique, tips, and "kill" stories from the Drag Strip. No street racing discussions. |
09-10-2007, 04:29 PM
#1 (permalink)
Proven Member
Region: Western Canada
2G 16" Wheel/Slick Combo
Does anyone know what wheel/tire combo well work on a 2G, I want to find a set of slicks for my car but need to clear my Willwood brakes and I'm 99% sure a 15" won't. Thanks Ron
Offline
09-10-2007, 06:24 PM
#2 (permalink)
Proven Member
Region: Mid Atlantic
Quote:
An inexpensive combo would be 16X7 or 16X8 Rota Slipstreams with a 26X9.5 Hoosier Quicktime slick. Very light weight.
Offline
09-10-2007, 07:49 PM
#3 (permalink)
Proven Member
I didn't think a 26" well fit on the 2G though?
Offline
09-10-2007, 08:13 PM
#4 (permalink)
Proven Member
Region: Midwest
Yes they will. 26x9.5x16 on a 16x7.5 with a 45mm off set. You will need a small spacer on rear. And that is with Willwood brakes.
____________________________
11.3@127mph (stock 7bolt)
Offline
09-10-2007, 10:23 PM
#5 (permalink)
Proven Member
I just went on there website and don't see this size listed? Am I missing something?
Offline
09-10-2007, 11:31 PM
#6 (permalink)
Proven Member
Region: Pacific Northwest
Summit racing is where I went to get mine and dont forget youll need tubes for the tires.
Offline
09-11-2007, 03:34 PM
#7 (permalink)
Proven Member
Thanks I found them on Summit!
Offline
09-11-2007, 06:10 PM
#8 (permalink)
Proven Member
Good, thats the cheapest I found, and Rotas were from www.machiii.net, thats also the cheapest.
Offline
09-13-2007, 11:10 AM
#9 (permalink)
DSM Wiseman
Region: Central Canada
Ron, was curious which Wilwood setup you are running? I to am looking for slicks or drag radials but wasn't sure if a 16" rim would clear my Wilwood kit. I tried a stock set of GST rims & was left with something like 1mm clearance between the caliper & outer portion of the rim.
Offline
09-13-2007, 06:38 PM
#10 (permalink)
Proven Member
DynaPro Big Brake Front Hat Kits:
Forged Billet DynaPro 4 Piston Caliper
12.19” HP or SRP Performance Rotors
GT Series Aluminum Hats
Performance Brake Pads
ABS Compatible
Offline
10-01-2007, 10:07 PM
#11 (permalink)
DSM Wiseman
Region: Midwest
Quote:
That is exactly what I run, and have had good success with them. I have had to use a 3mm spacer on the rear hubs to clear the spindles.
Tim Zimmer
2.3L Stroker, GT4088R, AEM EMS, etc.
Offline
10-01-2007, 10:08 PM
#12 (permalink)
DSM Wiseman
Region: Midwest
Quote:
Also, where i picked up mine.
The slicks I purchased from Summit.
I am also running a wilwood 12.2" 4-piston setup with forged superlites, no clearance issues at all.
I am NOT running tubes in mine, just tarred the hell out of them during the tire installation onto the rim.
Tim Zimmer
Offline
10-02-2007, 06:19 PM
#13 (permalink)
Proven Member
Who makes the forged superlites? Where did you guys buy your hub centric spacers?
Offline
10-02-2007, 08:47 PM
#14 (permalink)
DSM Wiseman
Region: Midwest
The forged superlites are a Wilwood product.
I cannot remember where I picked up the wheel spacers; it was from a vendor that specializes in 3000GT's.
here's an e-bay auction for some universals:
http://cgi.ebay.com/ebaymotors/Wheel...QQcmdZViewItem
Tim Zimmer
Offline
10-10-2007, 07:16 PM
#15 (permalink)
Proven Member
Anyone know where you can purchase hub-centric spacers for a 2G? (3mm)
Offline
10-11-2007, 12:42 PM
#16 (permalink)
Proven Member
Region: Midwest
I've got a nice set of 5mm spacers from Supercar-Engineering. They also sell 3mm spacers. They are not really proper hub centric, but they fit MUCH better than anything universal you can buy. I've ran them on my car for several thousand miles without any issue.
There is really no need for hub-centric-anything as long as you use self centering lug nuts.
http://supercar-engineering.com/sc2/...9455c494307722
Offline
10-12-2007, 05:30 AM
#17 (permalink)
DSM Wiseman
Region: Midwest
Good link -- This was where I purchased mine from in the past -- I just couldn't remember the darn website  !
Tim Zimmer
Offline
10-12-2007, 05:55 AM
#18 (permalink)
Proven Member
Thanks for the link!
Offline
10-25-2007, 08:14 AM
#19 (permalink)
Proven Member
Thanks for the info in my thread. Do you think instead of 3mm spacers I would be better to order 16*7 45mm offset for the fronts and 16*8 48mm offsets for the rear? That should eliminate the need for spacers correct?
Offline
10-26-2007, 10:55 AM
#20 (permalink)
Proven Member
Region: Gulf Coast
Are there any springs that will still allow you to run a 26" tires on a 2g? The parts car I bought came with a set of Koni yellows so I would like to use them w/o going to a ground control set up.
Offline
10-26-2007, 12:19 PM
#21 (permalink)
DSM Wiseman
What is the clearance issue, between the tire & the knuckle? If so, going to a 48mm offset is going to make the issue even worse, as it tucks the rim further in. If you need more clearance between the tire & the knuckle you want to run a smaller offset to push the tire further out (closer to the fender)
Offline
