Slappster
- 1,046
- 1
- Jun 20, 2002
Flower Mound,
Texas
Ok to start off I'm gettin this theory from things I've heard and puttin them together in a thought process. So their not very good sources
but here goes.
Wouldn't runnin 19s on a FWD help launchin from the line. Since with a gst stock with stock rims/tires it spins in 1st and only gets worse with each mod. Obviously 19s slow a cars acceleration more and also the weight of the 19s would slow it some more. So slowing the acceleration down some with the 19s I'm thinkin launchin in a GST would be helped with those larger rims. Now they wouldn't compare with slicks with would help acceleration so much that the "spinnage"
would be bad but much faster. Sure everyone wants a fast launch but when I've tried launchin mucho fasto I sometimes spin all the way to third and it doesn't help anything. I've found that layin off the gas from a launch then punch it when tires get some traction helps or at least seems to.
However the strength of the gst lies on the highway. And from what I've heard somewhere that big rims somehow help at large speeds so maybe it would even help with that. I highly doubt that one though. Ok im done.
Let the flames fly.
but here goes.Wouldn't runnin 19s on a FWD help launchin from the line. Since with a gst stock with stock rims/tires it spins in 1st and only gets worse with each mod. Obviously 19s slow a cars acceleration more and also the weight of the 19s would slow it some more. So slowing the acceleration down some with the 19s I'm thinkin launchin in a GST would be helped with those larger rims. Now they wouldn't compare with slicks with would help acceleration so much that the "spinnage"
would be bad but much faster. Sure everyone wants a fast launch but when I've tried launchin mucho fasto I sometimes spin all the way to third and it doesn't help anything. I've found that layin off the gas from a launch then punch it when tires get some traction helps or at least seems to. However the strength of the gst lies on the highway. And from what I've heard somewhere that big rims somehow help at large speeds so maybe it would even help with that. I highly doubt that one though. Ok im done.
Let the flames fly.
