Got Grip
- 289
- 262
- Sep 17, 2002
Philadelphia,
Pennsylvania
I dont post here often so I am sure none of you know my car or mods.
I have a 95 GSX with the following:
1G BOV
K&N® Air Filter
DSM-Performance Cast Intake tube (MAF to Turbo)
Thermal Research 3" Cat Back Exhaust
Joe P. Manual Boost Controller
ACT 2600 Pressure Plate and Street Disk
Fidanza Lightweight Flywheel
The car still has the stock turbo, IC pipes, stock IC, stock down pipe and stock cat, the only mods are those listed above and all my runs aer at full weight and I was only at 15psi.
Best run:
60' 1.867
1/8 8.891
MPH 77.996
2nd best:
60' 1.912
1/8 9.005
MPH 77.604
These runs were made at a small 1/8 track in South Carolina called Ware Shoals. Traction was becoming an issue as I was spinning all the way through first from as low as a 4500 slip.
I am pretty sure the car has solid 13's in it once I install my 3" down pipe and cat eliminator with tubular O2 housing. I will be in NJ in mid December just in time for Atco's last weekend of the year so hopefully I can get in some decent 1/4 runs in good weather. Let me know what you guys think. Sorry for the long post.
1G BOV
K&N® Air Filter
Best run:
60' 1.867
1/8 8.891
MPH 77.996
2nd best:
60' 1.912
1/8 9.005
MPH 77.604
