Czt
- Jul 24, 2003
I bought this Eclipse as a '92 GS and made it a '92 GST, kindof. The things I installed:
(all stock DSM parts)
1G Turbo
Exst Manifold
Oil Pan
MAS but not the airbox
Intercooler & Air Hoses
Oil Lines
Turbo Watercooling pipes
Things I wish I'd installed:
Oil Cooler
Oil Filter Housing
Throttle Body (garage mod on the N/T body to get the new hose to fit)
ECM (couldn't get one at the time)
Wiring Harness
A freaking boost gauge
Fuel Pump
T Fuel Injectors
T Air Box
EGT Gauge
Ok. Now the engine has a hole in a piston, and proably some bent valves. Basically, I want to follow the Turbo 1G path to 400HP, but I have qualms about the high compression ratio. Should I use a stroker kit to lower compression/increase CC? I know the engine needs some major $$, but once I get fuel management, manual boost control, etc. it really doesn't matter that it's not a stock turbo, right?
1G Turbo
Exst Manifold
Oil Pan
Oil Lines
Oil Cooler
Oil Filter Housing
Wiring Harness
Fuel Pump
T Fuel Injectors
T Air Box
EGT Gauge
