6-bolt 4g64 frontcase/oil pump?
Mine fits fine but im not sure about the difference in sensors a 2g might need.Mine is an early 1g front and 6 bolt 64 block in a 1g.Hope that helps.
Yes that answers it. I wasn't sure if a 6-bolt 4g63 frontcase/oil pump would bolt-on to a 6-bolt 4g64 block. Thanks for your help. :thumb:
I should have left out the 2g part...that might have confused a few people.
Say i posted somewhere on here about an high flow oil pump from www.importperformance.net wondering if anyone had ever used one.Its cheap,says $199 for gears and cover.Might be unneeded but,might be touch of insurance,if you're going to be buying one anyway.good luck.
Hose, I have seen the same front case. I am seriously considering it for my rebuild. You know, if you go to buschurs site, he recommends putting a new one on for a major rebuild. Sounds like sound advice.
I would shy away from a high-pressure pump, but a high volume seems like a good idea. Has anyone ever seen the trickle of oil that comes out of the turbo supply up on the head? I would like to hear from someone else using it--for God sakes, I don't want to be the first. : )
