Gst motor in a Gsx
Ice03
43
Jan 7, 2003
I thought all 4g63 were the same but I guess they are not. So here is my question what do I need to adjust to make my gst motor work in a gsx. So far everything has gone in except i can't get the tranny to work because the flywheel did not fit and now that I got a gsx flywheel i need to adjust the starter?? oh and i'm tryin to use a 7 bolt tranny with a 6 bolt motor, which I was told was possible?
need help quick.
You also need to get the plate that goes between the tranny and the motor. From a 7 bolt AWD car. You can use one from a 1G AWD, you just have to drill out the starter bolt holes. It is diffrent for the FWD's and they will not work, without some major modification, if at all.
