Calan
DSM Wiseman
- 7,250
- 398
- Jan 16, 2007
OKC,
Oklahoma
My machine shop accidently swapped the main bolt and stud for the oil strainer on my short block (they didn't have the front case, so it was an honest mistake).
As I was swapping and retorquing them, it dawned on me that I had really wanted to switch to ARP main bolts, but I let it fall through the cracks at some point during the parts ordering and machine work. So my question is...
Now that all the machine work has been done and the rotating assembly completed (as well as a good chunk of the timing components, etc)..... could I just swap out the stock main bolts one at a time for ARPs, without having to worry about any of the bearings shifting or having to disassemble it and take it back to the machine shop to have the caps align honed?
If so, what would be the best way to do it? Replace and retorque them one at a time, or replace one at a time "hand tight", and then retorque them all in sequence?
I plan on this motor lasting a while and want to do it right. If the stock bolts are good for 550-600 HP, I'm fine. Otherwise I'd like to swap them out.
.oO Can't believe I let that slip.... must be getting old
, but I'd also like the peace of mind with the ARP's instead of the old stock bolts if it's not a big deal.
