6 bolt swap : Oil Filter housing?
Rabbi
174
Mar 15, 2004
Muskegon, Michigan
I keep hearing about this 90 oil filter housing i need to run with my 6 bolt swap.
Ive searched a little and havent really found any answers as to why i must use this specific year housing.
Could anyone shine a little light on the issue?
Thanks
The 90 yr oil filter housing uses a external oil cooler. 91 up use a water-oil cooler. The 90 yr OFH help keep oil temps down alot better. Thats why everyone recommends to use this yr.
Hope this help :thumb:
Dam brian you beat me to it LOL..
If you live in a HOT area like Matt here It MIGHT not be helpful to run an AIR cooled oil cooler. Also if you're NOT driving and creating airflow its NOT cooling.
I keep my Coolant temps around 190*
COOLANT/WATER cools pretty efficiently, so maybe thats why mitsu changed to the Water cooled design for 91-99 DSM's
I always wondered if anyone has ever added an external cooler to a water cooled unit to double the cooling?
