mavisky
DSM Wiseman
- 5,390
- 62
- Sep 13, 2002
Atlanta,
Georgia
ok we all know that the 1g nt fuel pressure regulator has a base pressure of 47 psi, and that the 1g turbo has one of around 35 psi. in my current situation i have a 3000gt vr4 fuel pump and stock injectors. now that i've bolted my new 16g fuel rail on i decided to try out this alternative to fuel pressure control.
unfortunately i've yet to get very good fed back from my new o2 sensor since my transmission sprung a leak and won't be done til around til the end of the weak.
now on my car i still have the fuel pressure solenoid controlled by vacum hoses and then the nt pressure regulator. i realize the stock regulator has 1:1 rising rate action and based on the simplistic setup of the vacuum schematics. (manifold ->solenoid->regulator) my assumption is that the positive manifold pressure is being transferred through the solenoid and then acts in a rather simplistic 1:1 rising rate method by providing resistance to the diaphram.
my questions are as follows.
will this 1:1 rising rate action continue even on the nt regulator??
what exactly is the purpose of the fuel pressure solenoid??
