JWoodley
- 736
- 4
- Oct 12, 2002
Middle Of Nowhere,
Alabama
I have driven several DSMs with the full Prothane kit and while it proved to be a much better option than stock, I felt that the slack could almost entirely be eliminated.
I read and read and finally someone had the ingenious idea of machining aluminum full replacement inserts. I was a little late on jumping onto this bandwagon and got left out. Well as the case with most DSMers I wasn't afraid of a little experimentation and elbow grease.
Below you will find a progression of the mounts from start to finish. I anticipate making these for my friends 1G as well.
Let me know what you think:
I'm having a friend lay two beads along the inside of the rear mount for piece of mind and a little added strength. I'm going to drill the holes later this week.
Before I put them on the car I'm going to grind them down, or press them a bit more to get them even. I pretty anal about that kind of thing. Once that's done, I'm going to shoot the bodies of the mounts with some gloss black rattle can.
I'm debating polishing the front mount for the bling factor, but I'm going to have to be awfully bored for that one.
I'll update the thread later on with the final product and a few pictures of the drilling process.
nice man, i like it. However learn to use your phone
. hold it steady for just a sec and you'll have a nice pic with your iphone, not hard.
