black_gst
- 2,467
- 29
- Jun 16, 2008
IE,
California
So here's a quick write up that will show you how to install my polyurethane roll stops. It is pretty basic for most of you, but I do have a few tips.
So you just got you box from the UPS guy and you tear it open and you can hardly believe how beautiful the parts are!
Now that the initial shock is over, you notice a couple thing that you're not sure how you are supposed to use or don't know what to do with it.
The 1st thing you notice is this half of a ring
Well this pic ^ should help you, the stock rear motor mount is weak and this little half ring will stop you from bending the mount up when pressing out the stock bushing and when pressing in the included sleeve. But wait what sleeve?
^ That one, so once you either cut out the stock bushings or press it out, either will work, now you need to press in this sleeve. This will make the stock mount a bit stronger and give the bushings something nice to slip into.
I highly recommend a press
You will notice that for some reason one side of the stock mount had a slightly larger diameter press the sleeve into the smaller side and make sure you keep it as straight as you can. Also putting the sleeve in the freezer and heating up the mount will make things a bit easier.
So now you have your sleeve installed!
Looks sweet right?
Well that is the hardest part of this, so if that was easy for you then the rest is a breeze!
Now you have the front motor mount and if you have ever installed any other polyurethane motor mount this one is no different
On the right is the front mount, and the stock bushing has already been removed and again you can use a press or a reciprocating saw to get the mount out, then just clean the mount up a bit with some sand paper on the inside and slip in the new bushing!
All said and done you should have something that looks like this
Now to install them!
A couple tips when installing these, I'd recommend getting both mounts in place before bolting either of them down all the way. Now remember the center holes are not centered so you can rotate them to get them pretty close to lining up, now they still might be far enough off that you can't get the bolt through, what I did was loosen up the motor mount bracket a bit so you can line everything up, then bolt everything down nice and tight!
Enjoy your mounts!
and for those of you who bought from me please leave Classifieds Feedback , Thanks
************REVISION TO INSTALL************
I have since revised the sleeve for the rear mount, so if you have the new revised sleeve
you now need to press the new sleeve in from the larger diameter side of the rear mount to the small side, you must still use the half sleeve provided to keep the mount nice and straight while pressing or knocking out the old rubber mount and while pressing in the revised sleeve
Looks sweet right?
Enjoy your mounts!
