csc52blue
- Feb 5, 2011
middletown,
Ohio
need a lil advice love my car runnign the standard shift 2.4 sohc nt spyder backing out of drive way pnee day and put car in 1st gear went to take off and car fell on its face tried for around 5 minutes to start and finally it started sounding like it was running on 2 cylenders changed the plugs and ran good for a couple minutes then fouled them out again burning gas like crazy and heres the kickr i have to startr the car with ether before it will run on its own i have already changed the aic tps maf map temp sensor crank and cam sensor timing components cleaned the carbon track from the intake and ran seafoam through the motor cause the car was smoking black when i hit the gas im just lost someone mentioned low compression would i possible need to shange the head gasket even though there is no antifreeze in the oil or overheating though when i remove my oil cap after running the oil on the cap looks milky but thats the only place it looks like that or maybe rings in lost please some one help
has burt exhaust valves bad caped with crap on them pistons looked clean no scaring on the walls drained the coolant and oil before removing and still had coolant in cylender 1 and 3 or 2 and 4 how ever that goes o and i have it put on the scan at auto zone and it came up o2 and maf i changed them and still didnt help anything
