WTB: CGY Eclipse GSX/Talon tsi AWD
I am selling my '92 eagle talon tsi awd turbo. Asking $3500.00 obo. I am also throwing in about $1500 worth of extra parts. This car is now considered a classic due to the year and are very hard to find. Bought off original owner 4 years ago. Car runs great. Small idle fluctuation that i am working on now. As well as preping it for paint. I have alot of new o.e.m. Parts on this car that i can't even remember. I am an ase certified master tech & master chrysler/mitsu tech of 14 years now so for the most part. This car is in great shape minus the paint and idle flucuation. Also front drivers seat torn and needs blower motor resistor. I will prob. Have the idle and resisitor fixed soon. I am only selling because i have another baby on the way and need the $ asap to throw down on a mini-van for the wife. I do not want to sell it! But i have too, plus i own 2 more cars. I will add more pics later too.
Engine mods/services:
Original rebuilt 4g63 - 6 bolt engine!
New cylinder head w/15 miles on it
arp head studs
3rd gen hydralic lifters
cometic racing head gasket
tdo5h 14g turbo
greedy tvvc manual boost controler
2.5" o2 tubular o2 housing
2.5" downpipe to high flow cat
new timing belt, water pump, balance shaft belt
k&n air filter
rerouted/modified smic piping
vdo 3 pod guage set - boost, narrow band air/fuel, egt guages (needs new probe)
front upper strut brace
cross drilled rotors - front & rear
mercedes amg 16" rims (weigh 14.5 each with tires)
oval slowboy muffler
new front door 5.25 speakers (sony explode)
new rear 6x9 rockford speakers
new jvc detach face cd player w/aux jack
both front hub bearings
both front outer tie rod ends
ngk plugs w/8mm red plug wires
new mopar performance battery
8,000k hid head light set up (ice blue)
new state inspection
complete (red) set poly engine mounts
new transfer case
gsx rear spoiler conversion
theres more but i don't remember
extra parts that go with the car:
Brand new true evo 3 tdo5 16g turbo (never used!)
slowboy racing tubular manifold
turbo smart dual port blow off valve
new fmic - will need fmic piping to use
stage 2/3 hybrid atc clutch set
je 20 over bore pistons w/arp rod studs
front c/v axles
extra rear brake calipers w/brakets
o.e.m. Radiator w/both fans
2 extra 205/55-r16 tires
o.e.m. Tsi rear spoiler
and alot more, too much to type
serious inquires only. No low ballers please. Contact bobbie via call/txt at
7 five 7- six 0 four- 99 zero 2
